It is currently Thu Aug 14, 2025 10:21 pm
PostPosted: Sun Mar 08, 2015 2:59 am
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
Just published a little post about the cheap tool I use for shaving braces:
http://www.theluthierblog.com/articles/ ... ail-plane/
What do you use?
nigel
PostPosted: Sun Mar 08, 2015 3:56 am
One of these, with all edges slightly rounded:
http://www.ebay.co.uk/itm/Mini-Brass-BL ... 1031575171
It's set for a 'medium' cut. Blade is thin but it's perfectly adequate for braces/struts. I then finish off with a smaller Ibex flat Violin malkers plane, set very fine. That gives the finished surface. I try to avoid the use of sandpaper, if only to save my lungs. I inherited the Violin makers plane but I'd just buy two of the Rosewood/Brass planes if I didn't have the Ibex.
PostPosted: Sun Mar 08, 2015 6:10 am
Last Name: Matthews
State: Surrey
Country: England
http://www.bobmatthewsguitars.co.uk
PostPosted: Sun Mar 08, 2015 7:43 am
First name: nigel
Last Name: forster
Country: england
Bob Matthews wrote:
I've got one of those chisels for cleaning up glue. What's the little plane?
nigel
PostPosted: Sun Mar 08, 2015 8:26 am
Last Name: Matthews
State: Surrey
Country: England
The little plane is made by Steven Boone http://www.studioboone.com/mini_planes
PostPosted: Sun Mar 08, 2015 8:29 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
The plane is from Stephen Boone - he has a sponsor's link at the top. I have a set of his planes & like them a lot.
Kevin Looker
edit
looks like we posted simultaneously
I'm not a luthier.
PostPosted: Sun Mar 08, 2015 8:54 am
I use tapered braces and don't scallop as such my braces are predominantly shaped with finger planes except for the ends where I use a chisel to shape and size.
Before Stephen Boone's excellent planes were available I used traditional finger planes and they worked well except for the sharp angled side edges. Back then I would use masking tape and tape down about .010" acetate next to the brace that I wanted to plane the sides into a V shape so that the planes side edges did not mar the underside of the top.
When I started using Stephen's planes because he bevels the side angles acetate was no longer needed in that Stephen's planes won't mar in my application if you use them correctly.
The LN special edition plane pictured I no longer have and was not keen to use because it was to...... well...... pretty and I'm not a collector of planes.
I have the Kunz plane too and liked it a great deal but after getting the LN version the Kunz never got used again.
PostPosted: Sun Mar 08, 2015 12:01 pm
A 1" chisel with rounded corners and a set of Boone planes. Which reminds me I need new ones, I've pretty much worn mine out...
PostPosted: Sun Mar 08, 2015 3:00 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
My Boone plane!
Mike Collins
PostPosted: Sun Mar 08, 2015 9:25 pm
Boone planes! Nothing better.
PostPosted: Sun Mar 08, 2015 9:58 pm
Online
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I almost exclusively use an LMI Chisel on which I have rounded the back a bit. I do use boone planes a lot, especially if I need to take a brace down quite a bit.
PostPosted: Sun Mar 08, 2015 11:51 pm
First name: Zac
Last Name: Stout
City: Floyd
State: VA
Zip/Postal Code: 24091
Boone plane and a chisel for me as well.
PostPosted: Mon Mar 09, 2015 2:22 am
Last Name: Kincheloe
1/2" chisel and Boone plane. But I'd really like to get a 5/8" chisel and round the corners since I do usually scratch the soundboard in a couple places even being as careful as I can.
I bought a 3/4" paring chisel a couple years ago and rounded the corners, but ended up not liking it. Can't hold the soundboard in place well enough with one hand, and it's heavy and clumsy feeling compared to my short 1/2". Plus the length gets in the way when I get to the open backed box stage, and I always do a little more carving at that point.
PostPosted: Mon Mar 09, 2015 6:04 am
Just a regular ol chisel and plane. no point in gettin fancy with this stuff.
Under Compensated Nut!
PostPosted: Mon Mar 09, 2015 8:31 am
This is pretty much the main culprits - couple of LN's, inexpensive but good Chinese wooden planes ($15 a pop, shape sole to suit), a Veritas miniature block, Sorby 1" and a Henry Taylor 3/4".
Can't get no Boone planes outside the North American Continent anyway.
Sorry, no artfully posed handful of shavings... but plenty dust on the floor.
PostPosted: Mon Mar 09, 2015 3:29 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I also use both of Stephen's mini-planes when carving braces. I love the curved one for the tapered ends
PostPosted: Mon Mar 09, 2015 5:24 pm
First name: Jim
Last Name: Kirby
Stew-Mac glue clearing chisel to scallop brace ends, Ibex finger plane to shape/triangulate the braces. That's it.
Jim Kirby
kirby@udel.edu
